It is currently Sun Nov 22, 2026 5:21 pm
PostPosted: Fri Apr 29, 2011 7:35 am
I want to put a more aggresive set of gears in my rearend, however frm what I'm reading a dana44 seems like a better bet.... we have lots of jeeps out here, can I just go find a suregrip dana44 and put some 4.09 gears in it and get the off the line oomph I'm looking for? Or do I need axles etc? I've been reasearching this but I'm having trouble finding definitive information...
PostPosted: Fri Apr 29, 2011 8:43 am
How bout some definitive information about what you are trying to do....like what kind of car/truck you have?
PostPosted: Fri Apr 29, 2011 12:14 pm
Sorry... its a 73 dart custom 4 door... I want a suregrip diff with some stiff gears 3.55 or above....
PostPosted: Fri Apr 29, 2011 12:55 pm
No, it's never as easy as it seems.
If you have a 7 1/4 rear end (9 bolt cover) the Sure-Grip part is going to be tough. Gears from the later C-clip 7 1/4 (10 bolt cover and tapered axle tubes) as used in early Dodge Dakotas should fit and many had 3.55s. I tried pulling such gears in a wrecking yard, but in all 3 that I tried the lock pin for the differential cross shaft broke. If the lock pin breaks off the cross pin doesn't come out and the axles won't come out so you can't remove the differential carrier or pinion. :?
Most people don't bother with the 7 1/4 rear end as it's not very strong and parts are just as expensive as a stronger rear end like an 8 1/4 or 8 3/4. The only rear ends which bolt to the springs other than A-body rear ends are those from Ford Mavericks and Granadas or their Mercury twins the Comet and Monarch.
There is plenty to read about rear end swaps.
http://slantsix.org/forum/viewtopic.php?t=42674
PostPosted: Fri Apr 29, 2011 1:10 pm
Ok cool thanks!
PostPosted: Sat Apr 30, 2011 5:50 am
my brother and I replaced my pegleg3.55 with posi 4.10 in my 8 1/4 in one day under shade tree
keep on roddin'
PostPosted: Sat Apr 30, 2011 7:38 am
keep on roddin'
Word... what did you get it out of?
PostPosted: Sat Apr 30, 2011 8:19 am
it is in my 1981 d-150 truck.....able to pull heavier load easier...can spin both rear tyres...love driftin' in/on snow/mud/dirt roads...quicker takeoffs...more fun to drive...cannt wait to put cam,doubleroller chain,dultra duel duels,cut head with oversize valves,4bll offy on it
....waiting for machince shop to call that head is done
keep on roddin'
Indian
PostPosted: Sat Apr 30, 2011 12:25 pm
Did you keep stock springs? Did you use just the pumpkin or the whole shebang?
PostPosted: Sat Apr 30, 2011 4:24 pm
left rear in truck r&r pinon and whole ring,pumpkin have not messed with springs yet?????
Users browsing this forum: Google [Bot] and 9 guests
