It is currently Fri Nov 13, 2026 8:00 pm
 Post subject: starter
PostPosted: Wed May 04, 2011 9:24 pm
OK, may sound kinda dumb of me to ask, but there are two wires to the starter. One goes to the starter relay and the other goes to which, the relay or the battery? Just want to make sure on this...
PostPosted: Thu May 05, 2011 8:18 am
You can run the larger wire to the battery or to the main post on the starter relay where you would then have a large wire from the battery.
The smaller wire attaches to the starter relay, just in a different spot.
~RDE~[/list]
PostPosted: Thu May 05, 2011 10:31 am
Site Admin
There should be a large wire coming from the battery to the large starter post. Then there is a 10 or 12ga wire coming off of that same starter post to the large post on the starter relay. This wire powers the rest of the car. The smallest wire on the starter also goes up to the starter relay. This wire activates the starter through the starter relay. Hope that helps.
Chuck Rivers, Webmaster
Image Image Image Image
