| 1980 van slant head https://slantsix.org/forum/viewtopic.php?t=44886 |
| Author: | 6s\ant6 [ Sun May 08, 2011 3:21 pm ] |
| Post subject: | 1980 van slant head |
Hey all, I was at the junkyard today and saw a slant head from an 80 ram van, but I know that the motor used hydraulic lifters. Could I snag this head and pretty much bolt on to a 71 225? I stole the intake, exhaust and carb from it. Please let me know if these heads are interchangable/somewhat interchangeable, because that head looked good. |
| Author: | SlantSixDan [ Sun May 08, 2011 3:34 pm ] |
1981 was the first year for hydraulic lifters. The '81-'87 heads bolt onto the '80 and earlier blocks, but you have to use the '81-'87 valve cover and if you're keeping your solid lifters you have to use the '80-and-earlier rocker shaft, rocker arms, and associated hardware. |
| Author: | 6s\ant6 [ Sun May 08, 2011 6:57 pm ] |
| Post subject: | side q |
Hey Dan, Could you point me to that neat article about modding your intake from a 1bbl to two? Thanks for all your help here. Jeff |
| Author: | SlantSixDan [ Sun May 08, 2011 7:03 pm ] |
parallel 2bbl setup Glad to help. |
