| engine id https://slantsix.org/forum/viewtopic.php?t=44939 |
| Author: | userhelp [ Thu May 12, 2011 10:20 am ] |
| Post subject: | engine id |
I have just bought a car that had a slant six out into it. i can not see the engine number and there is no id marks that i can see to tell me what they model is or what the year is. can anyone give info as to how i can id the motor, only thing i know is that it has a one barrel carb |
| Author: | wjajr [ Thu May 12, 2011 2:36 pm ] |
Several spots to look for casting & other [url=http://www.mymopar.com/index.php?pid=31] numbers[/url] are: Above freeze plugs on left side of block On top of machined surface of block protruding out from under head below plug # one behind alternator. Under valve cover between valve springs and driver’s side of head. Transmission & rear-end will have numbers stamped and or cast on them as well. Additionally one can tell if engine is a 170cid. by measuring short coolant hose between water pump & head. If it is about 1" it's a 170cid., if it is about 3" it could be either 198cid. or 225cid. This thread should be moved to “Other†|
| Author: | userhelp [ Fri May 13, 2011 11:49 am ] |
| Post subject: | found engine number |
i found the engine number, it is 28107188 does that give me any info on the engine type or year of the engine anything else tnx |
| Author: | Fopar [ Fri May 13, 2011 12:54 pm ] |
"On top of machined surface of block protruding out from under head below plug # one behind alternator" The numbers will be hard to find, clean the dirty goo off and you should be able to read them. Richard |
| Author: | Reed [ Fri May 13, 2011 1:07 pm ] |
Compare the block casting numbers to the numbers found HERE. |
| Author: | wjajr [ Fri May 13, 2011 2:17 pm ] |
Me quoting me: Quote: Several spots to look for casting & other numbers are:
Above freeze plugs on left side of block Click on red words for a hot link to more information. In this case it will take you to a Mopar decoding site. |
