It is currently Sat Jul 18, 2026 8:01 am
 Post subject: fuel pressure gauge?
PostPosted: Mon May 16, 2011 4:48 pm
do you run one or two/ one under the hood and one on dash..
what range of gauge do you run>any special line for your gauge?
slant six's RULE!
http://www.usajon.com
PostPosted: Mon May 16, 2011 7:25 pm
6 Pack Dart
If you want to install a fuel pressure gauge in the dash (inside the car) you will have to get a special unit that fits on the engine side to prevent fuel from being able to get inside! That is why you will see fuel pressure gauges mounted outside on the area just ahead of the wiper blades.
Richard
PostPosted: Mon May 16, 2011 7:42 pm
In all seriousness, a fuel pressure gauge is one of the last things on the list of things you would need to add. They look cool, but that's about it. :shock:
PostPosted: Tue May 17, 2011 9:08 am
stock pumps do have issues
slant six's RULE!
PostPosted: Tue May 17, 2011 9:20 am
The one I have is electric, not mechanical.
I can easily move the sending unit around to check pressures at different places.
PostPosted: Tue May 17, 2011 11:04 am
who makes that
slant six's RULE!
PostPosted: Tue May 17, 2011 2:26 pm
Whatever you do, do not get a liquid filled gauge. They are not accurate.
PostPosted: Tue May 17, 2011 3:01 pm
looking @ Jegs they have sweep and digital gauges which one is best?
also they have a swept that only goes to 15 lbs? is that enough?
thanks all.
slant six's RULE!
PostPosted: Tue May 17, 2011 4:01 pm
who makes that?
The one I have is an Auto Meter gauge but there are others.
PostPosted: Tue May 17, 2011 4:41 pm
If a stock pump makes 5 psi you've got a good one. :shock:
PostPosted: Tue May 17, 2011 5:41 pm
OK
slant six's RULE!
