It is currently Mon Nov 23, 2026 8:53 pm
PostPosted: Mon May 16, 2011 12:03 pm
904 automatic
I'm pulling the valve body to install TG-2 shift kit. I can not remove the parking rod. last time i did this, it pulled right out and pushed back in. How do i free it?
thanks
keni
isaiah6:8
www.kenithomas.com
PostPosted: Mon May 16, 2011 12:46 pm
Rotate the drive shaft some. Make sure the car is in neutral too.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon May 16, 2011 3:08 pm
Got it. Thanks for the help
isaiah6:8
www.kenithomas.com
PostPosted: Mon May 23, 2011 10:28 pm
Hey kennicb are you rebuilding your trans or just swapping out the kit. I am wanting to do the same to min but Im not sure how to go about it. Its already out of the vehicle but I havent tried a trans yet. So far I have an offer for $500 to do the rebuild. If its not too hard Id rather do it myself
PostPosted: Tue May 31, 2011 9:02 am
hey Dean,
the transgo shift kit install is somewhat of a "medium difficulty" task . It wasn't as easy as I had hoped. but not as hard as it could have been. You will need a drimmel tool or a grinder to do some cutting on the metal parts. The directions are not the easiest to follow and do not cover taking it out and putting it back in the vehicle. For that you must refer to your manuals. But you can do the install by yourself. The challenge was that I'd never been inside a transmission and had no understanding of what anything in there did.
The shifts are harder and firmer now, but beyond that, I honestly don't see a big benefit. But I don't race. So if you are looking for tenths of seconds then it will help. But for me, In retrospect, i probably would have left the transmission as is and spent the time working on something else.
An entire transmission rebuild is beyond what I would want to attempt. Too many moving parts and special tools required. High margin of error for me.
one thing to always remember when deciding what to upgrade and not to upgrade. We read the sites and the mopar articles and get excited about more horsepower and performance. But performance is relative to everything else. You have to upgrade everything else before you begin to feel the change in doing one thing like installing a shift kit. Make sense?
The engineers who designed these vehicles were smart guys. We have a saying in the military, "if it ain't broke, don't fix it."
Good luck and Godspeed
isaiah6:8
www.kenithomas.com
