It is currently Thu Oct 01, 2026 8:33 am
 Post subject: Fried Parking Brake!
PostPosted: Sun Jun 12, 2011 5:02 pm
a friend has 1964 Dodge D100 2x4 truck.. it has the parking brake running off the back of the trans- it was used with the parking brake on..needless to say the parking brake is fried!
i took a look to where the noise was coming from.. there was a bunch of spring material sticking out from the drum- i opened the inspection plate and pulled out a handful of broken metal..(looks like 3/16 spring steel) i have never taken one of these apart.. (and no manual).. i need to order parts..
so far i have only been able to find bands and a cable, no hardware.....
any suggestions?
rich
Rich Sandomeno
www.spragwerks.com
PostPosted: Sun Jun 12, 2011 5:14 pm
http://seattle.craigslist.org/skc/pts/2429637921.html
PostPosted: Sun Jun 12, 2011 8:48 pm
Dang! i should have mentioned.. the truck is an automatic..push button-
Rich Sandomeno
www.spragwerks.com
PostPosted: Sun Jun 12, 2011 10:08 pm
www.oldmoparts.com
PostPosted: Sun Jun 12, 2011 10:20 pm
thanks-
Rich Sandomeno
www.spragwerks.com
PostPosted: Mon Jun 13, 2011 8:25 pm
I'd have to check, but I don't think I have a FSM old enough for what you're working on. However, someone on the forums over at www.sweptline.org could probably scan a few pages of a manual if you're still needing more detail/info.
