It is currently Fri Jul 17, 2026 10:29 am
PostPosted: Fri May 27, 2011 3:07 pm
OK
now my tach works correct
Ive mounted some N tires that are 23 inches instead of 27.5, I want to shif tomrow @ 75-80 dragway..Ive been told that 4500 is the point to shift.
it is all stock
so I start out in 1 then shift into 2nd @ 4500, then if need 3 rd @ 4500
is this correct..
any ideas using foot brake what rpm I stage @, then dump throttle on last yellow..any help would be apericated.
slant six's RULE!
http://www.usajon.com
PostPosted: Fri May 27, 2011 3:53 pm
I would shift the stocker at 4000rpm. JMO
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
 Post subject: Try it out
PostPosted: Fri May 27, 2011 4:16 pm
Just try different things Jon. With a stocker you will feel it quit pulling. No use to hold it there if it quits pulling. Let us know how much you pick up with the shorter tire.
Rick
PostPosted: Sat Jun 04, 2011 3:45 pm
well I get to the track late. 1 hour for tech line and TNT are racing while Im in line for tech..got through tech and I said Im in fro SE right , he said no that I had paid for TNT, got that all straight and told tech guy i need runs to see whats going. smaller tires/shifting now. I get one run in TNT shifting @ 4K as motor started petering out and then they call for SE times runs we got 2. I jutt put in in D as that is $$$ race..trans in D would shift into 2nd @ 3900 then 3rd @ 3200..got elimted 1st round by a Hemi jeep (new) young girl driver(pink full face helmit w/stickers)..yep. next race day 4me will be TNT . i dialed a 2low time and that was that.
slant six's RULE!
PostPosted: Sat Jun 04, 2011 4:09 pm
The 1-2 shift at a 3900 RPM is fine for a stock engine, but 2-3 needs to be around the same engine speed. 3200 is too low and costing you ET. I would put the shifter in 2 next time and make the 2-3 shift manually. A manual 1-2 shift takes a long time and slows the car down because manual low applies the low/reverse band.
PostPosted: Sat Jun 04, 2011 4:50 pm
USAJon, you may eliminate some problems with a shift correction kit, see this link.
This is a kit for improving things like weak 2-3 shifts, and increasing the life of your transmission, and correct little design flaws, it is not a 'shift kit'.
BTW, Oregon Performance Transmission has a very good rep. and deliver on time.
Olaf.
Aspenized
PostPosted: Sat Jun 04, 2011 5:01 pm
OK
I can manuel shift, but 2day @ the track because I got there late ..I only got minimal test run of 1 shifting. i had signed up for the $$$ race..which had only 6 peeps..
$150 2win, $75 runner up..and My dialed in time was 19.40, but that was way to low as my best time was 19.524 i just got nervous that I might run out..need more seat time.
slant six's RULE!
