It is currently Tue May 05, 2026 10:54 pm
 Post subject: Cl - Vc...???
PostPosted: Mon May 30, 2011 7:04 am
Hi,
Is it possible for CL front disc breaks to fit my VC Valiant? I'd be buying these:
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :MEBIDX:IT
If they fit I'm prepared to pay a decentish amount (Well what they are worth + a little extra)
Thanks.
PostPosted: Mon May 30, 2011 8:02 am
It certainly can be done. Believe you need the upper control arms to match the later disc brakes -- that's how it is when swapping later brakes to earlier American Valiants, and I'm pretty sure the same is true with Australian cars. If no Ozzies pipe up here, ask on www.moparmarketforum.com .
PostPosted: Fri Jun 03, 2011 6:14 am
Yes they will fit, the only drama you will have is a different stud pattern to the rear. Vh onwards is a larger pattern, you should be able to use vg discs on those stub axles tho.
