| Better carb for 1BBL manifold? https://slantsix.org/forum/viewtopic.php?t=4516 |
| Author: | Jopapa [ Fri Nov 22, 2002 11:40 pm ] |
| Post subject: | Better carb for 1BBL manifold? |
Well the Dart needs a new carb, and since I'm focusing on piecing together the parts for converting it to EFI, I'm not gonna focus on rebuilding the old Carter on there now. Is there a carb that might help wake the motor up a little better than a Holley 1920 or the stock Carter, without replacing the manifold? It's not really needed, but would be nice if one's readily available to be popped on. |
| Author: | Matt Cramer [ Sat Nov 23, 2002 2:07 pm ] |
| Post subject: | Pro Line Fuel |
ProLine Fuel sells a kit to put a two barrel Webber on the stock manifold. |
| Author: | Jopapa [ Sat Nov 23, 2002 6:20 pm ] |
Whoa for those prices I could get a new manifold anyway Methinks I should just keep myself content with stock until I start doing performance work I'm sure once I redo the valves and piston rings it'll feel a little better anyway... |
