It is currently Sun Oct 11, 2026 10:59 pm
 Post subject: Timing Set
PostPosted: Tue Jun 07, 2011 2:17 pm
Hi all,
S.A. Gear (Advance Auto), Napa, and Autozone all have a timing set with 3022 in the part number.
Does anyone know if these are all Cloyes timing sets, rebranded for each retailer?
Thanks. - Mac
 Post subject: SA Gear
PostPosted: Tue Jun 07, 2011 8:06 pm
All of the below will probably be from the same forge/parts machiner as a single chain.
SA Gear has all the Double Roller parts that Cloyes used to carry over the counter (and the gears are stamped with the cloyes numbers), but you have to order all the parts separately if you go that route.
Too bad you weren't able to get in on a group buy...
 Post subject: Timing chain sets
PostPosted: Thu Jun 09, 2011 6:21 am
Car Model: 1983 d150 a833 vin m
The chain and the crank sprockets are the same for a 440.Only the cam sprocket is different.Autozone does list the premium engine double roller components separetly.Elgin industries list machined parts (cam,lifters,oil pump) for the slant 6 and list the timing componets separetly.I deal with a shop in Il.,and its about $65 for the 3 pieces. Your still going to have to drill the cam sprocket and use the degree ecentrics -And theese guys are the only ones in the midwest rebuilding the Chicago power units.All 225's
I may be slow,but I"m ahead of you.
PostPosted: Thu Jun 09, 2011 10:22 am
I have a brand new premium Rollmaster double-roller set, bought a couple months ago, with multi-keyway crank sprocket that I'm not using in the foreseeable future. Would like to turn it around and get it off my shelf in Seattle; send me a PM if interested.
Users browsing this forum: Amazon [Bot] and 27 guests
