It is currently Thu Oct 08, 2026 6:35 am
 Post subject: Carb indentify
PostPosted: Mon Jun 13, 2011 6:19 pm
I picked up a spare carb at a local yard today for my 82 d150. It supposedly came off the same year. The chrysler part no. is 287033, carb no. is 40056, and what I think is date code 2912. Anyone know what this was originally used on? It does not have the bowl vent solenoid.
Dogear
PostPosted: Mon Jun 13, 2011 6:38 pm
None of those is a valid number. Chrysler P/Ns have 7 digits (newer ones, starting in the early 2000s, have 7 or 8 digits plus two letters). "40056" is not a carburetor number. 2912 isn't a meaningful number either.
If you see four numbers following the word "LIST", that'll be a Holley number. Maybe you'd do better to post some photos.
PostPosted: Mon Jun 13, 2011 6:47 pm
If the carb is truly the original 1982 carburetor, then it will be a Holley 1945 or a Holley 6145. Pictures will help greatly in identifying your carburetor.
 Post subject: 1982 carb
PostPosted: Mon Jun 13, 2011 8:09 pm
Thanks for your response. I should have known to take pix. I left off the 4 in front of that part number. The original carb on the truck is 4287015. This one should be 4287033.
https://picasaweb.google.com/ka9tez/Dod ... directlink
Let's see if these pix work.
PostPosted: Mon Jun 13, 2011 8:20 pm
Holley 1945 with the idle speed solenoid.
PostPosted: Mon Jun 13, 2011 8:51 pm
Thanks, Reed. It appears to be the same as the original, with some differences, such as bowl vent solenoid. I was hoping the part no. would tell what vehicle it came on, just for my own curiosity. So far I haven't found a link to Chrysler carb part numbers.
Dogear
PostPosted: Mon Jun 13, 2011 10:03 pm
That's like the 1945 I pulled off an 85 d150. I'd imagine you have leanburn so this probably wouldn't apply. But my carb that had a bowl vent solenoid had a ported spark tube. The 1945 from the '85 didnt have a bowl vent solenoid and didn't have a ported spark tube either. So if you ever do hei you will have to get a new carb. I just got a 1920 because I swapped throttle bodies and found out afterwards it didn't have a ported spark tube for vac advance.
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Mon Jun 13, 2011 10:16 pm
Ross, I appreciate the information. I'll keep that in mind if I ever do the HEI conversion.
Dogear
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 172 guests
