| engine identification https://slantsix.org/forum/viewtopic.php?t=45361 |
| Author: | dan Brooks [ Sun Jun 19, 2011 10:43 am ] |
| Post subject: | engine identification |
Hi, I'm new here but have recently bought yet another 1968 dodge dart. This one has a slant six in it and would like to know if this is the original engine. The only numbers I have found so far are located above the left side motor mount and are, 2806830-4 121271 aawj upside down W I've been told by the identification plate that the car originally came with the 170 motor. I want to keep this one as original as possible and use it for my summer driver as it's very clean. basicly no options but very clean. Thanks for all your help, Dan Brooks danielgbrooks@yahoo.com |
| Author: | SlantSixDan [ Sun Jun 19, 2011 11:01 am ] |
| Post subject: | Re: engine identification |
Welcome here. Find the numbers stamped on the top surface of the block, facing the sky, below the frontmost spark plug, inboard of the coil/alternator bracket. You will usually have to scrape and clean away grease and crud to see them. Quote: I've been told by the identification plate that the car originally came with the 170 motor
What are you seeing on the ID plate that tells you that?
| Author: | ceej [ Sun Jun 19, 2011 11:04 am ] |
The casting number is for an iron 225. It's not a 170. CJ |
| Author: | dan Brooks [ Sun Jun 19, 2011 6:12 pm ] |
[quote="SlantSixDan"]Welcome here. Find the numbers stamped on the top surface of the block, facing the sky, below the frontmost spark plug, inboard of the coil/alternator bracket. You will usually have to scrape and clean away grease and crud to see them. [quote]I've been told by the identification plate that the car originally came with the 170 motor[/quote] What are you seeing on the ID plate that tells you that?[/quote] I had someone else decode this tag through the gts registry for me, doesn't mean he's right but he's the only person I know who does this kind of stuff. If you know of someone else who can do it I'd love to give the information to them as well. I'll look for the other numbers tomorrow, Thanks, Dan. |
| Author: | Reed [ Sun Jun 19, 2011 6:34 pm ] |
Quote: The casting number is for an iron 225. It's not a 170.
Whatever the car originally came with, it has a 225 in it now.Scan a pencil rubbing of the fender build tag, or post a clear picture of the tag, and someone here can decode it for you. |
| Author: | ceej [ Sun Jun 19, 2011 6:38 pm ] |
The bottom line of the fender tag should start with an Exx. E11 would be a 170 E24 would be a 225 CJ |
| Author: | SlantSixDan [ Sun Jun 19, 2011 6:53 pm ] |
Ceej, it's a '68. Last year for the old-style damn-near-unparsable fender tags. What is the car's VIN? |
| Author: | ceej [ Sun Jun 19, 2011 7:20 pm ] |
Ahhh! That's why I shouldn't try to decode stuff! Didn't the '68 have a build sheet in the back seat or behind the glove box? Or is that from my Disco era cars as well? CJ |
| Author: | emsvitil [ Sun Jun 19, 2011 9:04 pm ] |
Quote: Ahhh! That's why I shouldn't try to decode stuff!
My 64 had a build sheet under the rear seat AND behind the glove box.
| Author: | dan Brooks [ Mon Jun 20, 2011 5:21 am ] |
[quote="SlantSixDan"]Ceej, it's a '68. Last year for the old-style damn-near-unparsable fender tags. What is the car's VIN?[/quote] the vin is- LL21B8B285418 |
| Author: | dan Brooks [ Mon Jun 20, 2011 5:41 am ] |
[quote="SlantSixDan"]Ceej, it's a '68. Last year for the old-style damn-near-unparsable fender tags. What is the car's VIN?[/quote] Here's the tag numbers hope I send this right, here goes, First row is a-z second row- there's nothing third row- a-z Fourth row- under the x there's a number 2 fifth row- there's a 1-8, under the two there's a 5. under the 5 there's a 5 fifth row- there's ax, under the A is a 1 fifth row-TRM- under the T there's a L. Under the R is a 4. Under the M is a B fifth row- PNT- under the P is a W. Under the N is a W. Under the T is a 1 Fifth row- UBS- Under the U is a U Sixth and final row- LL21 511 212 191424 please let me know if this is right and if you need anything else. Thanks guys for all your help, I am just trying to put as much information together as I can possibly can. Thanks again, Dan. |
