It is currently Mon Nov 16, 2026 6:54 pm
 Post subject: Wiring diagram please
PostPosted: Tue Jun 21, 2011 12:50 am
Hey guys
I wanted to get all my inline fuses and relays in one place, so I got an under hood fuse box that holds up to 9 relays and countless fuses out of a 3rd gen dodge caravan. I need a wiring diagram for this box. I've been doing continuity testing on this thing for over four hours and still keep coming up short on wires. If you have a wiring diagram with the fuse box for a 96-2000 dodge caravan or Plymouth voyager could you please post it so I can wire it into my truck correctly.
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Wed Jun 22, 2011 2:31 pm
Google has some millions of things to say on the subject. I have not searched it in fine detail for you - that's up to you.
Iwould be surprised if what you want is not available there.
Rod :?
PostPosted: Wed Jun 22, 2011 3:00 pm
Well, if you bought a factory relay housing, I imagine there should be a ground bus bar, a (+) bus bar, the trigger wire for each relay, and the load/accessory wire for each relay. Pick one relay socket at a time and trace the wires.
Alternatively, and assuming the housing uses Bosch relays, find the universal wiring diagram for Bosch relays and match the pin-hole in the housing to the function on the relay. This way you know what wire does what when you match the wire to the pin-hole.
HERE is a page with some info about relays, HERE is another one.
PostPosted: Wed Jun 22, 2011 7:11 pm
Thanks guys I did do a google search but I actually couldn't find any diagram for this box. I'll do a more in-depth search and hopefully find something. I did continuity testing on every terminal and all 52 wires. I have two spread sheets on which wire goes where. I double and tripple checked them. I just have three terminals idk where they go. But I wiring diagram would be nice to recheck everything.
Cody
Ps they are Bosch style relays.
