| Wiring diagram please https://slantsix.org/forum/viewtopic.php?t=45380 |
| Author: | Ross [ Tue Jun 21, 2011 12:50 am ] |
| Post subject: | Wiring diagram please |
Hey guys I wanted to get all my inline fuses and relays in one place, so I got an under hood fuse box that holds up to 9 relays and countless fuses out of a 3rd gen dodge caravan. I need a wiring diagram for this box. I've been doing continuity testing on this thing for over four hours and still keep coming up short on wires. If you have a wiring diagram with the fuse box for a 96-2000 dodge caravan or Plymouth voyager could you please post it so I can wire it into my truck correctly. Thanks Cody |
| Author: | walpolla [ Wed Jun 22, 2011 2:31 pm ] |
Google has some millions of things to say on the subject. I have not searched it in fine detail for you - that's up to you. Iwould be surprised if what you want is not available there. Rod |
| Author: | Reed [ Wed Jun 22, 2011 3:00 pm ] |
Well, if you bought a factory relay housing, I imagine there should be a ground bus bar, a (+) bus bar, the trigger wire for each relay, and the load/accessory wire for each relay. Pick one relay socket at a time and trace the wires. Alternatively, and assuming the housing uses Bosch relays, find the universal wiring diagram for Bosch relays and match the pin-hole in the housing to the function on the relay. This way you know what wire does what when you match the wire to the pin-hole. HERE is a page with some info about relays, HERE is another one. |
| Author: | Ross [ Wed Jun 22, 2011 7:11 pm ] |
Thanks guys I did do a google search but I actually couldn't find any diagram for this box. I'll do a more in-depth search and hopefully find something. I did continuity testing on every terminal and all 52 wires. I have two spread sheets on which wire goes where. I double and tripple checked them. I just have three terminals idk where they go. But I wiring diagram would be nice to recheck everything. Cody Ps they are Bosch style relays. |
