It is currently Wed Jan 08, 2025 11:36 am
 Post subject: Drive Shaft Lengths?
PostPosted: Sat Jun 25, 2011 6:16 pm
Will be swapping a 833OD into the Duster with my 7 1/4. I have a good shaft for that.
Is there a difference in length when swapping to an 8 3/4?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun Jun 26, 2011 1:18 pm
The 8 3/4 is a bigger unit (longer distance from the U-joint to the wheel/axle shaft centerline) so it will need a shorter driveshaft. I'm sure someone can give you the exact difference in length you need.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Sun Jun 26, 2011 3:01 pm
You will have to shorten the driveshaft 1-3/4" for the 8.75 rear.
PostPosted: Sun Jun 26, 2011 5:10 pm
Thanks Dennis.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
