| Drive Shaft Lengths? https://slantsix.org/forum/viewtopic.php?t=45426 |
| Author: | Rug_Trucker [ Sat Jun 25, 2011 6:16 pm ] |
| Post subject: | Drive Shaft Lengths? |
Will be swapping a 833OD into the Duster with my 7 1/4. I have a good shaft for that. Is there a difference in length when swapping to an 8 3/4? |
| Author: | WagonsRcool [ Sun Jun 26, 2011 1:18 pm ] |
The 8 3/4 is a bigger unit (longer distance from the U-joint to the wheel/axle shaft centerline) so it will need a shorter driveshaft. I'm sure someone can give you the exact difference in length you need. |
| Author: | slantzilla [ Sun Jun 26, 2011 3:01 pm ] |
You will have to shorten the driveshaft 1-3/4" for the 8.75 rear. |
| Author: | Rug_Trucker [ Sun Jun 26, 2011 5:10 pm ] |
Thanks Dennis. |
