It is currently Thu May 07, 2026 5:44 pm
 Post subject: SCR vs. DCR
PostPosted: Sun Jun 26, 2011 6:20 pm
ok so this is a new variable that i have come across... i know that a big cam bleeds off compression and what not so i started looking...
and well im not sure i like what i found...
here are the specs on my motor (street/strip 91 octane)
3.480 bore
4.120 stroke
6.700 rod
.157 in the hole
3.510 bore head gasket .020 compresses
44cc chambers
cam's IVC is 67 (adv) and 51 ( @ .050)
cam is .475 valve lift 246 @ .050 106LSA installed @ 102
now the program i use to figure compression and what not says i have 9.96:1 SCR... good... i just went onto wallace and it said its 235.12ci and a 8.95 compression! based on this my DCR is like 7.6!
now i need to be a little closer to 8.5 to 9 DCR...
am i just missing a step or what? thanks guys...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
 Post subject: Nope that's right...
PostPosted: Sun Jun 26, 2011 7:46 pm
Double checked your numbers, they're right...If I were picking a cam with a 246 dur @ .050 I'd be shooting for the 10-11:SCR range and hoping for something in the 8.6:DCR range...
I usually deck the block pretty well, then fine tune the CR by shaving the head after I have checked the piston to deck height...Sounds like you need to deck the head a bit more to make it all jake...
Good Luck,
-D.idiot
 Post subject: Re: Nope that's right...
PostPosted: Sun Jun 26, 2011 11:04 pm
Good Luck,
-D.idiot
yea the head has .110 off and the block is .030 off (.157 in the hole) this was my first motor build so i would next tike start with the block and then the head...
