It is currently Sat Oct 10, 2026 11:24 pm
 Post subject: rebuilding the 6'r
PostPosted: Mon Jun 27, 2011 4:22 pm
I'm gonna have a local shop knock out the old cam bearings and put my new ones in. I believe I have everything from bearings to gaskets to oil pump. I was wondering if there is a good book or write up to put one of these these back together. I've done ance's and aircooled vws. First slant though, just thought it would be nice to have a nice set of guide lines to work by. If not I'm sure its not as tedious as a vw, and more straight forward thanks
PostPosted: Mon Jun 27, 2011 4:53 pm
Try the factory service manual. The manual for just about any year slant six powered vehicle should work for reassembly instructions, so long as you stay within the solid lifter/hydraulic lifter families.
PostPosted: Mon Jun 27, 2011 4:58 pm
Where do I go about getting one
PostPosted: Mon Jun 27, 2011 5:09 pm
Read thru some of the engine assembly messages already posted and also review the articles listed off the home page of this site.
http://www.slantsix.org/forum/viewtopic.php?t=38446
PostPosted: Mon Jun 27, 2011 7:01 pm
What Doc said. If you want to track down a factory service manual, try the reference section at your local library.
PostPosted: Mon Jun 27, 2011 7:02 pm
6 Pack Dart
My only sugestion is to trash the new old pump (most have soft drive gears). You might be able to get a hardened gear from "Doc" and get it put on the new pump.
Richard
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 15 guests
