It is currently Wed Oct 07, 2026 10:42 pm
 Post subject: 2280 Carb
PostPosted: Sat Jul 02, 2011 1:15 pm
I spent all day yesterday installing a 2280 2 barrel on my new 85 truck. The carb was bought at Carlisle and looked almost new, but that is all I know about it. It was extremely clean inside and out. I just basically looked inside for anything obviously wrong and put it back together. I bolted everything up and it fired right up. I adjusted the idle mixture screws and took her for a spin. Wow! what a difference a 2 barrel made. Everything seems to work well except for at idle. I appears to have a miss while it is in gear at idle. I didn't notice it at first in neutral but whenever I dropped it gear and the idle slowed down it is pretty bad.
As soon as the throttle is opened just a bit it smooths right out. So I'm thinking it is something to do with the carb. I have the HEI ignition on this truck and new cap rotor and plugs. No smog pump or EGR installed either.
To be honest I ran out of time to do any more to it last night but I will work on it Monday for sure. I want to reset the timing and double check for any vacuum leaks..etc. But is there something obvious that I need to look at on the carb?
I did look at the video that Dan posted a link to and it is good but i still need some guidance. I also have the article that Doc recommended on the 2280
Thanks to all you experts out there !!!!
Rick
 Post subject: bump
PostPosted: Sun Jul 03, 2011 11:30 am
bump
PostPosted: Sun Jul 03, 2011 12:10 pm
does this carb have the eletc bump to rase the idle?
slant six's RULE!
http://www.usajon.com
 Post subject: no
PostPosted: Sun Jul 03, 2011 1:51 pm
No it does not.
 Post subject: Leaks
PostPosted: Mon Jul 04, 2011 1:55 pm
Found leaks at the base of the carb and one bad one at the vacuum tree. After I fixed those she idles like a baby. I will post a note about my homemade kick down linkage. It may help someone else.
Rick
Users browsing this forum: Google [Bot] and 16 guests
