It is currently Sun Oct 25, 2026 3:21 am
 Post subject: engine identification
PostPosted: Fri Nov 29, 2002 11:07 am
how do i tell if an assembled engine is a 198 ?
PostPosted: Fri Nov 29, 2002 2:35 pm
Look between the alternator bracket and the head. There is a stamping pad on the block that sticks out from under the head. If you scrape all the gunk off, the CI number will be stamped there.:)
 Post subject: Engine ID Numbers
PostPosted: Fri Nov 29, 2002 10:14 pm
Here is a look at the boss on the block and the ID numbers stamped into it.
This engine is a 1962 aluminum block 225 (TA22)
A 198 will have some letters and "19" or "198" stamped there.
