| Looking for unique HEI coil wire https://slantsix.org/forum/viewtopic.php?t=45561 |
| Author: | the_shadow [ Fri Jul 08, 2011 4:06 pm ] |
| Post subject: | Looking for unique HEI coil wire |
I was going to buy a new coil for my HEI conversion when I aquired this: ![]() As the HEI article says that is not the correct module, I will be installing the correct one in its place. The problem is I can't find the correct spark plug wire for it. Here's the best close-up I could get of the spark port on the coil: ![]() It's sorta weird, like deep down inside there's a pin connector. I went to the autoparts store and the guy could not find one that I could use. We did manage to find some wires that would connect that to a normal spark plug male type fitting, but I need the female type that goes into the distributor. Would anyone happen to have a part number for a spark wire that will work for this coil? I believe it's from a late 90s or early 2000s GM rwd pickup truck. Thanks. |
| Author: | Reed [ Fri Jul 08, 2011 4:14 pm ] |
This is one reason why I like using Ford e-core coils. They are everywhere in the junkyard, and you can easily use the Ford coil to distributor wire. It isn't as tidy as the GM all-in-one package, but I use them in vans so I don't have fenderwells to mount stuff on anyway. |
| Author: | Fopar [ Fri Jul 08, 2011 5:06 pm ] |
PM me your address and I'll send you one (I have a bunch of them). Richard |
| Author: | the_shadow [ Fri Jul 08, 2011 5:38 pm ] |
Quote: PM me your address and I'll send you one (I have a bunch of them).
That's really, really nice of you, and I will do so. I was however hoping to get a part number so I could pick one up tomorrow and finish my HEI installation this weekend.
Richard |
| Author: | bigslant6fan [ Fri Jul 15, 2011 2:16 pm ] |
| Post subject: | . |
Most auto parts stores sell single ign. wires with different combo ends. |
| Author: | the_shadow [ Fri Jul 15, 2011 4:52 pm ] |
Oops forgot to update this one. I opted to buy a new ford coil instead so I could just use a normal wire. Thanks guys |
| Author: | Reed [ Fri Jul 15, 2011 5:22 pm ] |
Did you get a wire that works? When I installed an e-core coil on my brother's 83 Dodge van I used the stock coil wire for an 84 Ford van with a 351W. |
