It is currently Wed Oct 07, 2026 9:33 pm
As a slant drag racer, would you like another option for an electric water pump
Poll ended at Sun Nov 27, 2005 3:53 pm
Yes 50%  50%  [ 1 ]
No 50%  50%  [ 1 ]
Total votes: 2
PostPosted: Sat Nov 12, 2005 3:53 pm
Car Model: '23 T-bucket
I'm in work on a modified slant water pump housing. The idea is to build up a slant housing to accept a B/RB water pump. In this way, one could use an aftermarket electric pump (for the B/RB) on a slant.
Would any of you care to offer some input? If this works out, I may do a write-up for the SSRN, and I suppose it's possible I could find an aluminum caster to do a limited run of say, 50 pieces.
 Post subject: waterpump
PostPosted: Sat Nov 12, 2005 5:50 pm
Car Model: 1979 Dodge Aspen
are you just trying to run the pump on the street or to race ,i use a electric water pump drive from jegs
PostPosted: Sat Nov 12, 2005 6:45 pm
SSRN National Champion
As a racer my engine does fine with a stock pump with an electric motor driving a plastic fan and the pump . I can control the water temp and bring the car up to the temp i want. My temps at the starting line is 130 and after the run it is 160 . This suits my engine but it is a hard blocked race engine. A street engine could not run this setup. Doint Know. Street /strip might be defferent . Any technogly for a Slant would be helpful. Thanks Ron Parker :D :D
Hey Has That Thing Got A Bagel Bamboozler In It
 Post subject: Re: waterpump
PostPosted: Sat Nov 12, 2005 7:02 pm
Mikey.....I'm unfamiliar with the Jeg's setup. Is it similar to the Mr. Gasket or Moroso universal belt drive? If so, that's what I was thinking of getting away from, and being able to use the better pumps with the electric motor built right into the nose of the pump housing.
Roger
PostPosted: Sun Nov 13, 2005 6:55 am
I'd be interested if this setup can be used for street applications. I've been wandering if I can get one of those electric pumps to work on my car.... somehow she ain't like the slow traffic because of the low-flow-at-low-engine-revs thing. I guess that having increased the engine's power didn't help neither, cuz at a traffic jam I can't really keep the engine revving.... I have to feather the gas all the time....
Juan Ignacio Caino
 Post subject: reverse flow?
PostPosted: Sun Nov 13, 2005 8:51 am
I would be more interested in a reverse flow system. It would be more useful for turbocharged applications.
Thanks,
PostPosted: Sun Nov 13, 2005 9:06 am
Car Model: 1964 Valiant 2dr post
They sell remote mounted electric water pumps with more flow than the block mounted style. This gives more room for electric fan installations and alternate plumbing arrangments. Also, a smaller style alternator could then be used with easier bracket fabrication.
Water flow volume is critical in street driven applications because the water can boil around the exhaust valve almost instantly and high engine loads. These steam pockets can cause all sorts of localized problems in the combustion chamber and valve seat temperatures.
Electric water pumps have a constant flow, engine driven water pumps increase flow and pressure differential across the cylinder head interface with increased engine rpm.
For drag racing, the low volume is probably not an issue, especially with the slants heavy duty head deck...for higher rpm street apps or boost/nitrous apps, or people who road race or auto cross, I am not sure that an electric water pump (except perhaps the high dollar hi flow rated stuff) will provide long term reliable thermal cooling in the most important areas around the exhaust valve.
I have been studying cooling systems and thermodynamics for a long time looking to convert all my cars at some point to computer driven and regulated electric water flow.
This web site has really good basic info on cooling system theory and thermodynamics of cooling engines.
http://www.stewartcomponents.com/tech_t ... Tips_6.htm
They also sell one of the highest flowing (and costing) electric pumps on the market.
Oops...late...got to go to the Panthers game
Gearhead
64 GTO...10.80's@122 on street radials
Destroked 455, Qjet, stock ign, 2400 stall
64 Valiant
Old 225, 4spd, 2.92-8.75, 2bbl, headers
dual 2.25"
PostPosted: Mon Jul 11, 2011 9:04 am
What ever happened with this project?
Users browsing this forum: Bing [Bot] and 22 guests
