It is currently Sun Oct 25, 2026 10:07 pm
 Post subject: IDLE Speed drops
PostPosted: Wed Dec 04, 2002 6:36 pm
Just got my 65 back togather. Replaced the sheet metal front end. Rebuilt the Stock carter carb. Replaced the elect eng dist. Motor has typ exhaust manfold leaks l will take care if that soon and it may be the root of the problem.
Car drives well but when ever I come to a stop the torque converter pulls the motor down to like 300 RPM before the RPMs return to normal idle. Could the converter be too tight? The trans fluid is bad and I will change that as time permits.
Thanks
Wild 1 AKA William Robertson
Owner Builder
65 Dart 270 2 door post /6 stock
89 dodge diplomat
66 Plymouth Barracuda
70 Challenger 451 ( Sold )
95 Chy New Yorker ( Stock )
Last edited by Wild1_Robertson on Thu Dec 05, 2002 6:53 am, edited 1 time in total.
 Post subject: yep
PostPosted: Wed Dec 04, 2002 6:42 pm
i think you touched on it, yourself. I'd change that fluid and filter sooner than later.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
 Post subject: Rebuilt the Carb...
PostPosted: Thu Dec 05, 2002 4:28 am
The float level could be a little off, causing the idle to "dip" when you stop.
The float could be to high or low, I would try lowering it first, to see if anything changes.
 Post subject: do not think it is carb
PostPosted: Thu Dec 05, 2002 6:55 am
If I slow down but do not stop no problem until I lug the motor down to a stop. So IMHO it is not carb related.
Owner Builder
89 dodge diplomat
Users browsing this forum: Plymouth_Ruster and 9 guests
