It is currently Wed Nov 18, 2026 4:25 am
PostPosted: Wed Aug 03, 2011 9:20 pm
Ok so I was driving today and got on it because some a-hole in their brand new mustang decided to ride my a**. For some weird reason the 1-2 shift I lost all electrical and the motor cut out for a split second before going back to normal operation. Any thoughts on why this happened would be appreciated.
Thanks,
Seth
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
 Post subject: Check..
PostPosted: Wed Aug 03, 2011 9:32 pm
I'd check your ground cable and ground strap to see if they are attached to the block tight...next check your starter cables...
You don't have that pesky seat belt interlock override under the hood do you?
 Post subject: Re: Check..
PostPosted: Wed Aug 03, 2011 9:37 pm
Even if his were a '74 (only year to have the interlock) and still had the interlock, that wouldn't be it. The interlock interfaces with the starter circuit, not with the ignition or any other engine-run circuit.
Loss of full electrical is most likely due to a faulty connection at the bulkhead disconnect or at the ammeter gauge or at the fusible link connector.
 Post subject: Check....
PostPosted: Thu Aug 04, 2011 4:54 am
I agree with Dan......check the ammeter connections or bypass altogether. Cleared up a bunch of weird electrical anomalies for me.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Aug 04, 2011 8:14 am
Had something Like this happen to me a few months back. Under hard acceleration and shifting or hitting a bump in the road my stereo would turn off. Didn't know why. I looked at the grounds and sure enough the body ground screw was loose. I put a secondary ground wire going straight to the firewall just in case.
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Thu Aug 04, 2011 3:55 pm
Following up what DI said: Don't rule out the positive cable from the starter relay. I had mine short on the exhaust manifold, but only on left hand turns..... :shock:
PostPosted: Thu Aug 04, 2011 6:35 pm
Thanks everyone for the advice, I found that my fusible link wire was loose from its connection to the other wire.
Users browsing this forum: Ahrefs [Bot] and 1 guest
