It is currently Thu May 21, 2026 1:31 am
 Post subject: cam bolt torque
PostPosted: Thu Aug 11, 2011 3:58 pm
cant seem to find the torque spec of the cam bolt anywhere, and would you suggest a dab of red locktite?
PostPosted: Thu Aug 11, 2011 4:30 pm
1978 manual, 225 engine, section 9, page 16:
Tighten camshaft sprocket lock bolt to 35 foot-pounds.
Same page:
Timing cover and oil pan bolts; torque to 200 inch-pounds
Olaf.
Aspenized
PostPosted: Thu Aug 11, 2011 4:37 pm
Thank you very much sir
PostPosted: Fri Aug 12, 2011 4:41 am
Yes, definitely use loctite. I usually run mine to about 50 ft-lbs...
PostPosted: Fri Aug 12, 2011 10:34 am
Wow, the very first time someone called me sir...
Olaf. 8)
Aspenized
PostPosted: Fri Aug 12, 2011 7:57 pm
I agree with Lou,I had one come loose at 35lbs,Pulled it and used loctite at 50lbs,no more problems.This was on a motor I was spinning close to 6000.Mark
PostPosted: Fri Aug 12, 2011 8:40 pm
Well if factory says 35. I'm sure its fine with a stock motor with a nice dab of locktite.
Users browsing this forum: Google [Bot] and 6 guests
