It is currently Sat Jun 13, 2026 6:28 am
 Post subject: Bench seat hole plugs
PostPosted: Tue Aug 23, 2011 12:28 am
What have you guys with buckets used to fill in the holes where the bench seat mounts?
 Post subject: ???
PostPosted: Tue Aug 23, 2011 5:26 am
Things must be different on the earlier cars, on the '73-76 bucket cars, the outer bucket rails use the bench seat holes and a second set for the inner rail next to the tranny/drive line hump.
PostPosted: Tue Aug 23, 2011 7:12 am
Think they are called grommets or body plugs.
http://www.pentastarparts.com.au/sunsho ... list&c=510
If you measure the width of the hole you could send/call that website or check that listing and they might have something useful.
PostPosted: Tue Aug 23, 2011 8:07 am
You can get plastic body plugs (also called sheet metal plugs) in various sizes. I believe those are 3/8" holes. Caplugs and Niagara are big manufacturers. Mcmaster and other sites have these. Last bunch I bought were boxes of plugs from Ebay or Amazon...
I always mount my buckets (custom) using the bench seat holes (outboard) and then drill/reinforce for the inboard holes.
PostPosted: Tue Aug 23, 2011 9:58 am
Thanks everyone.
DI- I am not using the stock buckets.
Lou- I am using buckets out of a 97 camaro,and they bolt square to the floor with one inch spacers all around,so I wasnt able to use the bench holes. I do have them reinforced at all four corners :D
PostPosted: Tue Aug 23, 2011 6:18 pm
Like 14-12 ga plate 3"x3" min, or 16-18 ga channel 1/2"x1"x1/2"?
A set of fender washers aren't going to work well in a collison (been there, seen that...my buddy was at the hospital afterwards...).
PostPosted: Tue Aug 23, 2011 7:19 pm
I am thinking if I get into that bad of a wreck,I am a gonner anyways :shock: but yes using 1/8" steel plate to reinforce. I think they are 4x4.
