It is currently Sun Oct 25, 2026 8:57 pm
PostPosted: Wed Aug 24, 2011 4:50 pm
I have a problem with my D-150 I've never seen before. I can't get the distributor out! But first let me backtrack and give yall some background information.
This all started when my D-150 wouldn't start last week. It still has the lean burn computer and the dual pickup distributor with the later style hold-down. After some troubleshooting I noticed that the rotor wouldn't move when the engine was turned over. Ok that's no problem, I've had slant sixes break distributor gears before and they were a simple fix (hardest part was putting it back in and getting it timed on the first try).
Then the trouble started, I removed the hold down bolt and tried to remove the distributor. It wouldn't budge. So I pulled harder, and it will only rise up 1/4 inch and that's it. I've pulled the distributor on my Duster more times than I care to remember when I recurved it and I've never seen a problem like this. On top of that, I can't spin the rotor by like I could before when the gear broke. It's just stuck in that one position.
Anybody have any idea what is going on here? The truck was running fine before this happened.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Aug 24, 2011 5:42 pm
6 Pack Dart
Might be a peice of the gear jamed in there, try rotating the motor backwards to see if it will free up the distributer.
Richard
PostPosted: Wed Aug 24, 2011 5:44 pm
Already tried that, didn't work. Thanks anyway.
I'm not that worried about trashing the distributor, since this is the excuse I've been looking for to ditch the lean burn and put my super six setup on it. The only thing on the distributor I want to save is the holddown. I'm just worried that something else might be wrong besides just a broken gear.
82 D150-225/727
PostPosted: Wed Aug 24, 2011 6:04 pm
you do have holddown all way off???? spray some pentrating oil on base and rotate ...let sit overnite ...spray more in orning and rotate ....
pry it out
PostPosted: Wed Aug 24, 2011 6:05 pm
I have had distributors on other motors get a build up of sludge/carbon/varnish or whatever, and they would not pull out easily. they would rotate in the seated position, but would not come out. These were V8 motors and I just pulled and pried until they came out. Might try and use some PB Blaster or carb/brake cleaner and see if you can get some down there to see if that helps any. You would/should change the oil afterwards. Just some thoughts.....
Mike
Edit:....I see I was a bit slow on the keyboard....lol
An officialis Tyrde-Browne Racing membrum
PostPosted: Wed Aug 24, 2011 6:07 pm
Yes the hold down bolt is completely out. The distributor body will turn like it's supposed to.
You are probably right about the gummed up/sludge part. The distributor on this truck has never been pulled for all of it's 250,000 miles. Hard to believe the plastic gear and the lean burn computer lasted this long.
I'll try the penetrating oil and see if I can wiggle it out with two small prybars.
82 D150-225/727
PostPosted: Wed Aug 24, 2011 6:16 pm
If the rotor won't turn, maybe a timing chain/gear failure..??
Mike
PostPosted: Fri Aug 26, 2011 6:04 pm
Stuck a big screwdriver between the block and the flange on the distributor and it popped right out. Still have no clue what was holding it in.
82 D150-225/727
PostPosted: Fri Aug 26, 2011 6:16 pm
It seems very oily, and it is surprising how old, stale lube can make a vacuum situation, making it difficult to break the oil film tension.
My 2¢.
Olaf.
Aspenized
PostPosted: Fri Aug 26, 2011 7:28 pm
Does that dizy have a vac advance? If so what would you want for it?
Dave
1972 d-100 parts truck
PostPosted: Fri Aug 26, 2011 7:46 pm
It's a dual pickup lean burn distributor. has no advance weights or vacuum advance, but it does have a blank cover plate where the vacuum can would go.
82 D150-225/727
PostPosted: Fri Aug 26, 2011 8:43 pm
I'm looking for one that I can use for a basic HEI conversion.
Dave
 Post subject: But...
PostPosted: Fri Aug 26, 2011 9:04 pm
That plate is to cover the hole in the body...your pickup plate is fixed and has no provision to accept vacc. advance...you'd have to swap out the whole assembly from a regular distributor and a pickup from an autoparts store...
