It is currently Fri May 15, 2026 11:02 pm
 Post subject: blnker question
PostPosted: Wed Aug 24, 2011 9:28 am
Does anyone know if a 92 sundance has separate flashers for the driver and passenger turn signals? The driver side turn signal on my wifes car doesn't always flash, it frequently just comes on and does not blink.
PostPosted: Wed Aug 24, 2011 11:23 am
One flasher for left + right turn signals, one flasher for hazards. If one side doesn't blink, it means you've got a dead bulb or other circuit fault.
PostPosted: Wed Aug 24, 2011 6:45 pm
Thanks Dan, I'll go through all the bulbs then.
PostPosted: Fri Sep 02, 2011 11:59 am
The socket had a bad ground, everything is hunky dory now
