It is currently Thu Nov 26, 2026 3:56 am
 Post subject: adjust kick down cable?
PostPosted: Wed Aug 24, 2011 9:14 pm
I have a slant 6 and I installed the ProLine dual carb. how do i adjust kick down cable?
PostPosted: Wed Aug 24, 2011 9:44 pm
6 Pack Dart
Post a picture of your setup, then we can see what you are working with for linkage.
Richard
PostPosted: Wed Aug 24, 2011 10:55 pm
http://www.flickr.com/photos/66799403@N ... otostream/
i have the lokar inc, universal kickdown kit kd-2904ht & the cable brkt & springs srk-4000 if you need more pic's just let me know. thank's
PostPosted: Wed Aug 24, 2011 11:41 pm
6 Pack Dart
The kickdown cable should be hooked up so that it pulls the opposite of the throttle cable.
If the throttle cable is above the center of the pivot the kickdown is below pivot.
Richard
PostPosted: Thu Aug 25, 2011 6:48 am
Looks like the throttle will go on the bottom and the Kickdown up with the carb linkage.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Aug 25, 2011 8:04 am
i hooked up the accelertor cable but how do i hook up the kicked down cable so it will be pulling the opposite of the accelerator cable? photos of this setup would help me. here are more pic's
PostPosted: Thu Aug 25, 2011 8:26 am
You need to attach the kick-down cable in between the pivot point of that long arm that throttle cable is attached too, and the rod that couples both carburetor’s throttle plates. So when accelerator cable pulls to fire wall, kick-down cable gets pulled in direction of radiator.
You will have to fiddle around to find the proper ark, or travel distance to have throttle pressure lever on transmission bottomed out by pull of cable at the same time carburetors are full wide open.
PostPosted: Thu Aug 25, 2011 9:09 am
do you have any pic's so i can see what your suggesting?
PostPosted: Thu Aug 25, 2011 10:25 am
There are some pics of he original setup here.
When using a stay, the stay pushes the kickdown lever back against its rear positon. When using a wire, you need a bracket on the transmission so the wire can be mounted in a position where it can pull the lever back.
You will fnd complete, illustrated mounting instructions for the Bouchillon cable setup here, transmission pics near the bottom of the page.
Olaf.
Aspenized
PostPosted: Thu Aug 25, 2011 11:39 am
is this what you ment? how do i adjust it
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 9 guests
