It is currently Mon Oct 26, 2026 1:57 am
PostPosted: Fri Aug 26, 2011 10:32 am
Just got one for my 74. I could swear that the timing mark should index in line with the keyway. Mine is 10-15 degrees off. Normal ?
PostPosted: Fri Aug 26, 2011 11:29 am
Site Admin
Yes. When the keyway is vertical, the timing indicator on your cover is offset, so the mark on the damper should align with the indicator.
CJ
