| Quick quest. on PowerBond damper https://slantsix.org/forum/viewtopic.php?t=46111 |
| Author: | slanty6 [ Fri Aug 26, 2011 10:32 am ] |
| Post subject: | Quick quest. on PowerBond damper |
Just got one for my 74. I could swear that the timing mark should index in line with the keyway. Mine is 10-15 degrees off. Normal ? |
| Author: | ceej [ Fri Aug 26, 2011 11:29 am ] |
Yes. When the keyway is vertical, the timing indicator on your cover is offset, so the mark on the damper should align with the indicator. CJ |
