It is currently Thu Nov 26, 2026 9:22 am
PostPosted: Sun Aug 28, 2011 3:25 pm
OK
I plan to install soon/later a used Hurst ratchet shifter. I wondering if I can use self tapping bolts to mount to the floor instead of bolt/lockwasher/nut.
anyonw done this b4?
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Aug 28, 2011 3:41 pm
it might hold for awhile...better to drill holes and use bolts,flat& lock washers, and nuts
 Post subject: Tap
PostPosted: Sun Aug 28, 2011 4:02 pm
Jon You could run a tap up through the shifter holes and then run bolts down through. That will hold them up top for you while you go under to put washers and nuts.
Rick
PostPosted: Sun Aug 28, 2011 4:13 pm
yea
I just found the diagram for this unit. Hurst promatic 2
it has bolts/washers/nuts thanks all.
slant six's RULE!
 Post subject: Re: Tap
Rick
man thats tits on a ritz
thanks!
slant six's RULE!
