will these self tapping bolts work?
https://slantsix.org/forum/viewtopic.php?t=46134
Author:  USAJon [ Sun Aug 28, 2011 3:25 pm ]
Post subject:  will these self tapping bolts work?
OK
I plan to install soon/later a used Hurst ratchet shifter. I wondering if I can use self tapping bolts to mount to the floor instead of bolt/lockwasher/nut.
anyonw done this b4?
Author:  hantayo13 [ Sun Aug 28, 2011 3:41 pm ]
it might hold for awhile...better to drill holes and use bolts,flat& lock washers, and nuts
Author:  Rick Covalt [ Sun Aug 28, 2011 4:02 pm ]
Post subject:  Tap
Jon You could run a tap up through the shifter holes and then run bolts down through. That will hold them up top for you while you go under to put washers and nuts.
Rick
Author:  USAJon [ Sun Aug 28, 2011 4:13 pm ]
yea
I just found the diagram for this unit. Hurst promatic 2
it has bolts/washers/nuts thanks all.
Post subject:  Re: Tap
Rick
man thats tits on a ritz
thanks!
