It is currently Tue May 19, 2026 11:42 am
PostPosted: Mon Aug 29, 2011 7:02 pm
OK
who/where makes roller rockers for the slant six ?
thanks..
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Aug 29, 2011 7:09 pm
I did a search and found this
http://www.pentastarparts.com.au/sunsho ... tail&p=811
anyone else make em..?
slant six's RULE!
PostPosted: Mon Aug 29, 2011 7:17 pm
Don't take this the wrong way, but roller rockers on a Slant are pretty much a waste of money. Unless you are going to run stupid high spring pressures, they won't do anything for you but make a lot of noise.
Yes, I have 2 sets.
The car has been just as fast with RAS rebuilt stock rockers as it has with my Cox 1.6's. :shock:
I have a set of Goodman 1.5's too. Got a smokin' deal on them or they would be elsewhere. :oops:
PostPosted: Mon Aug 29, 2011 7:21 pm
I thought you were on a budget? If you want minimum ET for dollar spent your money should go elsewhere.
These rocker arms are made by Rocker Arm Specialist. I have a set. They were $300 down and $300 at time of delivery. I have them because my race engine will spin as high as 8000 RPM and I felt I needed the strength. Most 225s don't spin that fast and are fine with rebuilt stock rockers.
A $400-$500 high stall torque converter will get you a much better ET improvement than a $600.00 roller tip rocker arm assembly.
PostPosted: Mon Aug 29, 2011 7:25 pm
yes
budget, but i have no idea the price range of these..Ive seen SBC @ meets for $100 set used...so..I C your point here..$$ vs HP output.
thanks.
the torque converter is on list, probally will be a build on our spare 1969 drive train..winter probally...
slant six's RULE!
