It is currently Thu May 28, 2026 1:20 pm
 Post subject: Holley 1920 jet source
PostPosted: Sun Sep 04, 2011 9:40 pm
It seems that new Holley jets are available with part numbers such as 122-56 from a number of sources.
Do these jets actually resemble those used originally on the 1920? They appear to have the correct thread and the orifice appears to be .001 less then the original such that a 56 jet has a .055 orifice
Has anyone tried these jets to see if they fit the 1920?
PostPosted: Sun Sep 04, 2011 9:47 pm
Yep,they fit.
PostPosted: Tue Sep 06, 2011 8:13 pm
Yes, just about every auto part store I have visited has a selection. Sometimes you need to order the smaller sizes from Jegs or Summit Racing.
