It is currently Thu Nov 26, 2026 9:48 pm
 Post subject: Rebuilding A903
PostPosted: Sun Sep 11, 2011 5:55 pm
Hello, motor is going to the machine shop tomorrow and I would like to freshen up my A903. It shifted nicely (a little loose but that is due to linkage I believe)
I found a rebuild kit for it and its within my price range, however I cannot find any info on the process of rebuilding. Any info is greatly appreciated.
:D
PostPosted: Sun Sep 11, 2011 6:21 pm
6 Pack Dart
This is the manual that used to be on this site, but the server that it was on is no longer.
http://www.bulkpart.com/transmission-repair-manual.html
This will get you to where you can get your own book.
Richard
PostPosted: Mon Sep 12, 2011 5:51 pm
I appreciate that, however im only seeing manuals on the 904 and automatics.. Ill keep browsing through the site
PostPosted: Mon Sep 12, 2011 6:38 pm
6 Pack Dart
Sorry I thought you were asking for 904, the 903 is a manual trans.
Richard
PostPosted: Mon Sep 12, 2011 7:49 pm
I was able to find my old service manual, it gives steps to rebuild it however it goes over it as if ive done this a few times. Anyone gone through the 903? Is it difficult or worth the extra $$ to have a shop freshen it up?
PostPosted: Tue Sep 13, 2011 8:37 am
Personally, I do not think those 3-speeds are worth putting money into...
I would do a quick flush, fix any leaks and just run it until it needs replacing... then swap to a better trans.
PostPosted: Tue Sep 13, 2011 9:46 am
With the trans being tired wont a brand new motor blow it up fairly quickly? I love the column shift, so swapping a 4 speed is outta the question not to mention the $$ involved in doing a big swap.
Is there any other 3 speeds that will work with my column shift and be a better option than the A903? I also worry that I wont be able to run my new motor how I want too on a tired tranny. :shock:
PostPosted: Tue Sep 13, 2011 9:57 am
An A230 would be a stronger unit and those have a synconized 1st gear.
http://www.slantsix.org/articles/4-spee ... -swaps.htm
