It is currently Mon Oct 12, 2026 2:25 am
PostPosted: Fri Sep 16, 2011 8:14 am
Hello.
I building 225 engine with 2bbl carb, & i have two different camchaft to install:
№1
№2
Please explain the difference between these camshafts, and which of them is preferable to install in my engine?
1970 Dodge Dart /225
PostPosted: Fri Sep 16, 2011 9:37 am
Do you know what they came out of?
What is the lift?
What is the lobe separation?
Are you building a hydraulic or solid lifter motor?
Compression of motor?
No 2 is missing a piece from the lobe. I wouldn't use it except as a paper weight.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
