what is the difference camchafts?
https://slantsix.org/forum/viewtopic.php?t=46348
Author:  Rost310 [ Fri Sep 16, 2011 8:14 am ]
Post subject:  what is the difference camchafts?
Hello.
I building 225 engine with 2bbl carb, & i have two different camchaft to install:
№1
№2
Please explain the difference between these camshafts, and which of them is preferable to install in my engine?
Author:  snarl [ Fri Sep 16, 2011 9:37 am ]
Do you know what they came out of?
What is the lift?
What is the lobe separation?
Are you building a hydraulic or solid lifter motor?
Compression of motor?
No 2 is missing a piece from the lobe. I wouldn't use it except as a paper weight.
