It is currently Sat Oct 10, 2026 2:13 am
PostPosted: Mon Sep 19, 2011 7:00 pm
Car Model: 1987 Dodge D150 RWD,Slant 6,A833 transmission
I did a search and could not find this. I need to remove the trans pilot bearing from the end of the crank. It is not in the flywheel but at the end of crank. I need some tricks / advice that works for removing this. I am ready to start bolting trans,and new clutch with pilot bearing so it has to go!!
!987 D-150 Short Bed,Slant-6, RWD,A-833,2007 Ram Mega Cab 3500 RWD Cummins 5.9
PostPosted: Mon Sep 19, 2011 7:22 pm
6 Pack Dart
A simple old trick is to fill the bushing full of grease, then with a shaft the same diameter as the end of the input shaft, you hit the shaft (trying to drive it in) with a hammer.
The grease will not compress and will force the bushing out, or you can use a bushing removal tool.
Richard
 Post subject: Yep...
PostPosted: Mon Sep 19, 2011 7:34 pm
There are 3 ways to accomplish this task:
1) Fopar's way works good, especially if you have an old input shaft lying around from anotehr tranny you can beat on with a 5 lb dead blow hammer...(junkyard 3 speeds used to be good donors...)
2) You can buy a pilot bushing puller from a tool store (this assumes you will use it more than once (I've used my harbor freight one 3 times in 10 years...)
3) The caveman procedure says you can score it with a die grinder or sawzall blade or split it with a cold chisel and pry it out (do not nick the crank bushing cavity).
#1 is pretty slick if you have the items on hand
#2 at harbor freight is about $10.99
#3 I've done and is not easy to accomplish, and definately is a lot of time and sweat.
PostPosted: Mon Sep 19, 2011 7:40 pm
4) Cut some threads in the bushing, screw in a bolt as far as you can, and use a puller.(homemade version of #2) :D
Olaf.
Aspenized
PostPosted: Tue Sep 20, 2011 3:59 am
Thanks everyone! Great suggestions. I heard of the grease and driving a drift pin or old shaft in.I will have to check on the puller from Harbor Freight the store is not to far from me
Users browsing this forum: No registered users and 31 guests
