It is currently Fri Oct 09, 2026 9:10 am
PostPosted: Fri Sep 23, 2011 3:09 pm
I've got a 1987 Dodge Dakota.
Its 3.9 V6 is a cut-down 318 V8 that uses the v8-type distributor.
I'd like to ditch the factory computer and the distributor with the computer-controlled advance in favor of a the simpler mopar ignition system.
Would it be possible to convert the v8 type distributor to accept slant six internals? If so, what is needed?
TIA
--Walt Jackson
PostPosted: Fri Sep 23, 2011 3:39 pm
The 3.9 is not even fire, sorry. The crank pins are split 22° rather than 30° so the firing interval is 112°, 128°. I was going to put a 3.9 in my '64 Valiant at one time and made a custom reluctor with a rotary table on a friend's milling machine.
PostPosted: Sun Sep 25, 2011 8:02 am
I always wondered if somebody was going to put a "paintshaker" in a car. I have one in my Dakota, and it makes you appreciate the smoothness of an inline 6.
82 D150-225/727
02 Dakota-3.9/5 speed
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 11 guests
