It is currently Fri Nov 27, 2026 3:01 am
 Post subject: auto trans question here
PostPosted: Wed Sep 28, 2011 2:10 pm
has anyone ever losen up the trans line @ the rad /start up engine /clunk from park to reverseto drive to drain the fluid?
I dont need to pull the pan as the filter has less the 500 miles on it, but the fluid is a a tad dark a smells a tad burnt..tans shifts fine works OK
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Sep 28, 2011 2:20 pm
If you want to do it that way, just put the car in neutral. (Blocked so it can't move)
The pump circuit is active in neutral. :D
