| auto trans question here https://slantsix.org/forum/viewtopic.php?t=46479 |
| Author: | USAJon [ Wed Sep 28, 2011 2:10 pm ] |
| Post subject: | auto trans question here |
has anyone ever losen up the trans line @ the rad /start up engine /clunk from park to reverseto drive to drain the fluid? I dont need to pull the pan as the filter has less the 500 miles on it, but the fluid is a a tad dark a smells a tad burnt..tans shifts fine works OK |
| Author: | slantzilla [ Wed Sep 28, 2011 2:20 pm ] |
If you want to do it that way, just put the car in neutral. (Blocked so it can't move) The pump circuit is active in neutral. |
