It is currently Tue May 19, 2026 12:43 am
PostPosted: Wed Sep 28, 2011 10:49 pm
Ok, so I have suddenly gotten the problem of when my car is running and I turn the headlights on it pops one of the 20amp fuses and the car dies on the spot. Any responses would be nice. Am I looking at a voltage regulator? I have class tomorrow in the afternoon and i have to drive to Salem.
Thanks in advance,
Seth
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Wed Sep 28, 2011 11:01 pm
No, it's not the voltage regulator. Sounds like you have got a big, serious short circuit in your wiring. I sincerely wish you good luck in finding and fixing it.
PostPosted: Wed Sep 28, 2011 11:47 pm
ok, fun stuff :( I noticed that my amp meter was sparking a little last night, can I bypass the gauge all together, and if so how so? I already know that the needle is in the center all the time. A lot of my electrical problems have been due to the amp meter one way or another and I'm kinda tired of it.
PostPosted: Thu Sep 29, 2011 5:44 am
First investigate if the connections to amp gage can be made fast, or rather tight; double nutting may be necessary. If not able to repair, pull off both leads from amp gage, and tightly nut & bolt them together. Than tape that connection up real good so it dose not ground out on anything.
PostPosted: Thu Sep 29, 2011 12:12 pm
Ok, the problem is specific to the headlights, park lights work fine, but when its running and I put the headlights on all the way I am popping 30 amp fuses. What should I check? Headlight switch? Dimmer switch? Oh and when I would press the dimmer switch sometimes the low beams wouldn't come back on, just trying to tell you guys everything that is wrong.
PostPosted: Thu Sep 29, 2011 1:24 pm
Nevermind I found it. One of my headlight switch wires had rubbed partially and was touching metal. Thanks for the help guys
