It is currently Sun Nov 15, 2026 11:52 am
 Post subject: Thanks
PostPosted: Fri Nov 04, 2011 3:12 am
I would like to thank everyone on here for all the help. I decided about a year ago to convert my 80 Cordoba to fuel injection. I had a basic idea on what I wanted, an odb II based on a GM or Ford system. I started to do research and collect parts and last night I hit the key and the car started and ran for the first time.
Thanks again
PostPosted: Fri Nov 04, 2011 4:50 am
Congrats! Great job on your hard work. Let us know how it progresses...
PostPosted: Fri Nov 04, 2011 9:44 am
Congratulations! I'm sure I'm not the only one who'd like to know more about your setup, maybe see some pics or vids…?
PostPosted: Fri Nov 04, 2011 9:56 am
Absolutely. I am very interested to see your system working and get a full description of how it was done! Congratulations and please share.
PostPosted: Fri Nov 04, 2011 12:59 pm
Started and ran on the first try? Lucky! :)
What made you chose OBDII ? Aren't those a PITA to modify/tune ? Details!
PostPosted: Fri Nov 04, 2011 7:05 pm
I wanted ODB II but settled of odb I for the moment, still working on an idea on II.
I did a lot of documentation and will post more soon
PostPosted: Fri Nov 04, 2011 7:25 pm
Congratulations! It sounds like a great job, but...
Olaf
Aspenized
PostPosted: Fri Nov 04, 2011 7:33 pm
Thanks for getting back to us with an update. LIke all the others, I would like to know a bit more about the system you ended up with. Maybe make a little list of the details such as ECU used, ignition pick up used, injectors, sensors, etc?
Sam
PostPosted: Sat Nov 05, 2011 3:25 am
I'm still working on a detailed list of items but here is a start
I went to the junk yard and picked up a engine compartment wireing harness from a "89 diplomat to modify, if this didn't work I wanted to be able to go back easily.
I'm using a lean burn distributer with a single pickup, a DR140 wells ignititon module, coil from a 4.3 Chevy S10 and the ECU from a 87 Fiero 2.8
I had planned on using a MAF system but could not find one so I settled for the
MAP.
the Cordoba is running at this point but not drivable. I still have several items to wire in and clean up. one being the VSS
I'll add pics when I figure out how to
