It is currently Tue Sep 22, 2026 10:12 am
PostPosted: Sun Oct 09, 2011 1:11 pm
can I remove my lifters without pulling the head on a 1970 slant six..
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Oct 09, 2011 1:30 pm
Yes, unless a 1975-'80 cylinder head has been installed.
PostPosted: Sun Oct 09, 2011 1:57 pm
you've never lashed the valves on your motor have you?
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Oct 09, 2011 2:03 pm
yes
at the valve stem top when when hot..they were very loose on 3 of them.
we have had 11 drivers slant's over the years
currently only 2.
slant six's RULE!
PostPosted: Sun Oct 09, 2011 2:06 pm
yes
currently only 2.
my point was you can see the pushrod on top of the lifter(with light)
PostPosted: Sun Oct 09, 2011 2:30 pm
well your assuming that i have taken apart a slant six or know what one is supose to look like..
my past has been chevy 427 /mopar 440 big blocks and flathead/knucklehead/panhead/shovlehead Harleys
this is my first slant six fun project
all others were reliable drivers
slant six's RULE!
PostPosted: Sun Oct 09, 2011 5:45 pm
i not assuming you've done anything... thats why i asked if you have lashed it...
because you can see the pushrod sitting on top of the lifter... right below where you turned the adjuster...
