It is currently Sun Jun 14, 2026 1:38 am
 Post subject: Factory Hurst From Van
PostPosted: Tue Oct 18, 2011 5:32 am
I have a date to pull a complete slant OD set up from a late 70's van. Will that shifter work on an A body or other Mopar?
When I dropped the shorty 833OD in my Duster (vintage unknown) My firnd told me the reverse linkage may have been from a truck. It did make me cut the exhaust and I will need to re route that.
PostPosted: Tue Oct 18, 2011 8:17 am
If you use the van shifter in an A-body, the hand doing the shifting will be about even with the rear view mirror. Also, the van floor is flat whereas an A body floor is tilted. I encourage you to pull the complete manual transmission linkage form the van, including the pedal setup, but I doubt much of it will work in your Abody. You will have good luck selling the manual transmission setup to a vanner since they are always looking for the parts to convert vans to manual transmissions. Post the parts for sale over on www.vannin.com
PostPosted: Fri Oct 21, 2011 4:41 pm
shifter bolts to trans....just need to change handle arm/rod, the one comeing from shifter into car...it either is bolted in pace or you need two pieces of hacksaw blades to slide either side of it and pull,might be stuck( can be a Bitch sometimes}
