It is currently Fri Nov 27, 2026 8:11 pm
 Post subject: 3 speed in a 61 wigeon
PostPosted: Sun Oct 23, 2011 10:19 am
My boss has a 61 wagon with a floor mount 3 speed and he wants to swap in a auto, is this just a case of finding a 904a and a flexplate? He also wants to have a floor mount shifter, most likely to cover, of use the hole that is there. Please give me some guidance.
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Mon Oct 24, 2011 10:55 am
There is a little more to it then "just find a SL6 904 & flex plate"...
My first question is on the starter motor type, does the vehicle currently have a "direct drive" early Prestolite / Bendex starter or does it have a "later" gear reduction" starter? (122 ring gear teeth)
For a period correct installation, the 60 - 64 "cable shift" 904 would be a good choice but these all used a dash mounted "pushbutton" shifter.
The 904 auto will need throttle pressure or "kickdown" linkage.
Any automatic will, need a trans fluid cooler.
PostPosted: Mon Oct 24, 2011 1:13 pm
Thank you for the info I am going to go look at the car wed I am giving him my old holley 1920. I wish he would let me hook the push button and fix the hole.
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Mon Oct 24, 2011 1:35 pm
A good "Plan B" would be to use the 1965 cable 904 wiuth the optional floor shifter. That would be the last year of the "cable shift / flanged output 904 so the current driveshaft and speetometer cable would "bolt-in".
The trouble is that this is a "1 year only" set-up so finding all the needed parts could be a challenge.
PostPosted: Mon Oct 24, 2011 2:34 pm
I have one, that I picked up at a swap meet. I would have to check and see if it is complete, or if there are parts missing. If you are interested, let me know, and I will dig it out.
PostPosted: Wed Oct 26, 2011 7:42 pm
we talked about it and we are going to try to install the push button. His car does not have the controlls those. Is this a hard thing to track down and install
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Thu Oct 27, 2011 1:27 am
I used a pushbutton shifter/trans in my 66 Cuda. Mounted the PB shifter in a console on the floor, between the bucket seats. If you can't find the parts, send me a PM. I have some pushbutton shifter parts, and might be able to have enough for a complete assy.
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
