It is currently Sat Nov 21, 2026 7:36 am
 Post subject: Turn Signal - 61 Valiant
PostPosted: Fri Oct 28, 2011 3:33 am
My turn signal base (the part the turn signal lever screws into) is loose / sloppy. The base is held in place with a bolt and if it is too tight then it is difficult to use the turn signals. If it is less tight then the base becomes loose / sloppy after using the turn signal.
I need to know how to prevent the base form becoming sloppy / loose over time. I am becoming frustrated at removing the steering wheel to tighten the turn signal base.
Thanks.
