| Turn Signal - 61 Valiant https://slantsix.org/forum/viewtopic.php?t=46819 |
| Author: | crickhollow [ Fri Oct 28, 2011 3:33 am ] |
| Post subject: | Turn Signal - 61 Valiant |
My turn signal base (the part the turn signal lever screws into) is loose / sloppy. The base is held in place with a bolt and if it is too tight then it is difficult to use the turn signals. If it is less tight then the base becomes loose / sloppy after using the turn signal. I need to know how to prevent the base form becoming sloppy / loose over time. I am becoming frustrated at removing the steering wheel to tighten the turn signal base. Thanks. |
